[ANSYS Meshing] How to transfer bodies in FE Modeler to Initial Geometry
Old   May 21, 2013, 07:33
Default How to transfer bodies in FE Modeler to Initial Geometry
goddy72 is on a distinguished road
I have some pretty ugly NASTRAN meshes with material defined for the groups of elements. I have managed to import the meshes into FE Modeler.
In FE Modeler, the separate regions (corresponding to materials) of the mesh show up as separate bodies, and the material ID's have also successfully been transferred.
However, when I generate the Initial Geometry, the geometry generates as a single part, with 1000+ separate bodies.
All I want to do is be able to transfer the existing bodies (which are separate) into separate parts in the generated geometry, so that I am able to do structural analysis in Static Structural.
Help?
I've attached a screenshot to illustrate since my description suck.
goddy72 is offline   Reply With Quote
Old   May 24, 2013, 09:01
Default Additional Information
I am able to import the mesh (NASTRAN file) into ICEM.
Here the separate bodies show up as separate parts (Image shown Below).
I am trying to analyze the mesh in static structural, assigning a separate material property to each part.
There must be a way to do this. It's driving me crazy.
Additional information: At the moment I am linking ICEM to FE Modeler to Static Structural
Old   March 11, 2015, 03:18
Damir
londam is on a distinguished road
Hi goddy72,
did you managed to find the solution for your problem?
I don't have the ICEM, so I can't try what you described in your 2nd post.
londam is offline   Reply With Quote
transsonic nozzle with rhoSimpleFoam Unseen OpenFOAM Running, Solving & CFD 8 July 1, 2022 06:54
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 04:13
