Importing Points in Design Modeler
Like Tree4Likes
  • 4 Post By danh
Old   June 22, 2010, 13:49
Exclamation Importing Points in Design Modeler
Dan
danh is on a distinguished road
Does anyoane knows how to import several points in Design Modeler?
For example i have 50 points that are describing a spline curve(i have = i have the 3d coordinates - x,y,z) and i want to import them to Design Modeler and there i want to create a spline curve.
Can Design Modeler import "point files" or do i have to make a script? If this thing works only with a script does anyoane have an example of such a script?
Thanks in advance,
DH
danh is offline   Reply With Quote
Old   November 9, 2010, 12:50
rima is on a distinguished road
I am relatively new to DesignModeler and have the same question you had. Did you figure it out or do you have any advice?
Thanks!
rima is offline   Reply With Quote
Old   November 10, 2010, 09:47
Dan
You can find here:
http://www.cfd-online.com/Forums/cfx...ler-ansys.html
I will paste-it for you anyway:
# List of Point Coordinates
# Format is: integer Group, integer ID, X, Y, Z
# all delimited by spaces, with nothing after the Z value.
# Group 1
1 1 20.1234 25.4321 30.5678
1 2 25.2468 30.1357 35.1928
1 3 15.5555 16.6666 17.7777
#Group 2
2 1 50.0101 100.2021 7.1515
2 2 -22.3456 .8765 -.9876
2 3 21.1234 22.4321 23.5678
make a text file with above format, then to import into design modeller,goto [Create] menu -> Point
and select the file you've just created.
good luck
p36288, soheil_r7, Niraj and 1 others like this.
Old   November 10, 2010, 12:14
Thanks for getting back, it worked great with my MATLAB code.
Old   September 26, 2013, 14:54
Pjotr
oewnce932c is on a distinguished road
thanks!
have used this for my tutorial with naca wing
yachting_rus cup
world amateur racing tour
WWW.YRC.DK
oewnce932c is offline   Reply With Quote
Old   March 30, 2015, 10:45
Umair
umairrasheed99 is on a distinguished road
sir i am new here. kindly help me. actually i import points in design modeler and now am doing / making spline from these points but at end points are not meet each other and get like that:
how to eliminate this
umairrasheed99 is offline   Reply With Quote
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
Modeling Terrain in Design Modeler Will C ANSYS 0 February 26, 2010 18:13
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
Design Modeler to ICEM..... Joe CFX 0 January 24, 2008 03:39
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
