Home > Forums > ANSYS Meshing & Geometry
[ANSYS Meshing] Meshing for piston compression- deforming
Old   April 4, 2015, 11:04
Smile Meshing for piston compression- deforming
sanjeet Limbu
sanjeetlimbu is on a distinguished road
Dear all,
I am trying to simulate a rapid compression machine- it simulate the compression stroke in a cylindrical - axi-symmetric chamber containing mixture which is compressed by a piston rigid body motion. I made a udf for the rigid body motion.
But the I am facing the error when i use the mesh shown in fluent." Divergence detected- AMG solver issues- Enthalpy".
Please suggest how to get it done.
Also I am unable to view the mesh motion as per the UDF function for piston - named element.
The idea is to make the piston face move and adjacent interior cell compress/ by layering method. The velocity of piston as rigid body accelerate to a peak and decelerate to zero : this according to compression ratio 16.5.
The following is the udf:
#include "udf.h"
DEFINE_CG_MOTION(oscillate, dt, vel, omega, time, dtime)
Thread *t;
face_t f; /* define the variables */
t = DT_THREAD(dt); /* get the thread pointer for which the motion is defined */
/* if (!Data_Valid_P())
/* return; /* check if the values of the variables are accessible before you compute the function */
begin_f_loop(f, t) /* loop over each face in the zone to create an array of data */
if (time <= 0.010)
vel[0] = (600* time); /* define the velocity of the moving zone---*/
else if (0.01 < time < 0.019)
vel[0] = 6 +(888.89 * time);
else if (0.019 < time < 0.027)
vel[0] = 14;
else if (0.027 < time < 0.03)
vel[0] = 14 - (466.67*time);
else if (0.033 < time)
vel[0] = 0;
end_f_loop(f, t)
Pl suggest how to remove the negative volume issue[/QUOTE]
sanjeetlimbu is offline   Reply With Quote
Old   April 10, 2015, 08:33
Paritosh Vasava
vasava will become famous soon enough
Not that I am complaining but you are in the wrong part of the forum. You can post your question on the fluent forum and you might get help quickly.
First of all if you plan to use dynamic mesh do consider switching to tetrahedral meshes. As you can see in one of the pictures the problem is with the mesh update. You can try to use a smaller time step. For example a time step small enough so that the maximum displacement of the moving boundary is smaller than the smallest mesh element.
Also use appropriate dynamic mesh parameters. In the mesh method setting see the mesh scale info. Use these values in the setting. The AMG solver problem would be fixed once your time step is small enough and mesh quality is reasonable.
vasava is offline   Reply With Quote
Old   April 10, 2015, 09:03
sanjeet Limbu
ok i got the motion part done, i am getting the zone motion preview as needed.
but the mesh seems not good enough. that is now causing negative volume issue/error after few time steps(i tried lowering both time step and elemnet size but it may be due to the skewness)
Old   April 11, 2015, 10:57
sanjeet Limbu
Dear sir
I am getting negative volume error even after doing the edge sizing and mapping the mesh zones.
when i remove the crevice part and used the rectangle for cylinder shape only then it run, by reducing the time step to 4.16E-07s . But if i wanna use the crevice as shown in photos before the grid move for one cel length -first layering and instantly shows the error
I think the moving rigid body mesh - crevice is not having the grid in line -parrallel to the grid line in the body -part. They are at angle due to the crevice shape. how to make it work- please suggest
Old   April 13, 2015, 03:22
Paritosh Vasava
You have disabled Smoothing and Remeshing. Do enable these options and in the smoothing part play around Spring Constant Factor.
I still believe that 1e-3 sec. is a very big time step for that narrow region with 1 mm gap while the wall velocity is ranging from 6 m/s to 20 m/s. Try a drastically small time step lets say 1e-20 or 1e-10. Check the mesh motion and if everything seems alright increase the time step order gradually.
Old   April 13, 2015, 09:03
sanjeet Limbu
thanks
I will try that ... but teh time will increase i i go very low.. I managed to run using e-6s
I am getting some divergence error AMG solver- Enthalpy.
and some warning that the maximum temperature exceeded the PDF table
do you have any idea- i am using ignition delay model
Old   April 14, 2015, 01:43
Paritosh Vasava
I am not expert with ignition. But you can limit the temperature range and use smaller relaxation to keep solution going little further.
Thread Tools
Trackbacks are On
[ANSYS Meshing] Can I use ANSYS Meshing for manual meshing? Kirjain ANSYS Meshing & Geometry 6 November 30, 2015 09:11
Problems with Meshing of a Rapid Compression Machine FluentStarter FLUENT 2 April 19, 2015 18:48
dynamic meshing 2D compression piston KITetima FLUENT 3 April 19, 2015 14:22
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
