[ICEM] Blocking two different fluid zones
Old   April 16, 2015, 05:22
Default Blocking two different fluid zones
Dhayananth
dhaya400 is on a distinguished road
I am having two different fluid zones in my geometry.
How can I block the model separately ?
Also I need to create O-grid and internal walls between fluid zones.
with regards,
Dhayananth
dhaya400 is offline   Reply With Quote
Old   May 13, 2015, 04:59
Default Blocking two different fluid zones - help needed
Dhayananth
I am having geometry with two different fluid zones.
I find very difficult to block this geometry because one fluid zone is present inside the other zone.
Can any one please give some suggestions /methods to overcome my problem.
with regards,
dhaya
Old   May 13, 2015, 06:24
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hello dear;
Can you post the tin file? geometry?
since you are struggling so much I will give it a quick try
shereez234 is offline   Reply With Quote
Old   May 14, 2015, 00:00
Dhayananth
Originally Posted by shereez234 View Post
Hello dear;
Thank you for your concern and reply.
please find the geometry shared in google drive
https://drive.google.com/file/d/0B9q...ew?usp=sharing
with regards,
Dhayananth K
Old   May 15, 2015, 05:15
Dhayananth
I tried myself to block and mesh the geometry.
But near the connection, I am not getting proper mesh.
Please find attached picture of mesh.
with regards,
Dhayananth K
Old   May 17, 2015, 23:28
shereez234's Avatar
M Sereez
Originally Posted by dhaya400 View Post
with regards,
Dhayananth K
Hey man I was busy and caught up with some stuff. Sorry about the late reply. Good news is I gave this a 2 tries tonight Two tries because the geometry I have to say is a bit complicated. You had surfaces inside the fluid zone which I did not understand why it exists. Anyways here first have a look at the mesh;
and two pictures of blocking;
and the scane plane;
and download the blocking and project file from the link below from my dropbox.
Or and also the mesh quality atm is 0.15 and above. so try to improve it and yes it can definitely be improved. I thought to leave it for you as you will enjoy it
https://www.dropbox.com/sh/aee3qnmjo...EhgGrssWa?dl=0
Best regards
Shereez
Old   May 18, 2015, 00:19
Dhayananth
Attachment 39546
Attachment 39548
Attachment 39549
Best regards
Shereez
Thank you for your reply and concern.
The file which you shared does not contain two fluid zones. The difficulty in meshing arises when two fluid zones are present. At the junction of the connection you can find fluid zone1 and another one surrounds the fluid zone 1.
So can give some suggestions/ methods to mesh the geometry having two fluid zones.
with regards,
Dhayananth K
Old   May 18, 2015, 06:36
shereez234's Avatar
M Sereez
with regards,
Dhayananth K
Hey I did not use two zones; haha but of course you can put the blocks where you want a different fluid in a different part ( select blocks).
Old   May 18, 2015, 06:57
Dhayananth
Sorry I am not able to follow.
Can you please elaborate.
Old   May 18, 2015, 07:17
shereez234's Avatar
M Sereez
Dhaya; Can you let me know where you want the two fluid zones? it's best if you can show me through a picture then I will explain to you what to do.
What I did is put all the blocks in a single fluid part called "blocked"; I can put these blocks into different parts given that i wanted to do so;
so yeah be more specific and i will try help you
Old   May 18, 2015, 07:27
Dhayananth
Please find attachment
Old   May 18, 2015, 10:36
shereez234's Avatar
M Sereez
Dhaya you were right; when you try to put another block inside it gets all complicated; but when i disassosciated some faces and arranged the edges again ( after making a new part for the block which represents fluid2) the mesh seemed to be better. However , I am still unable to resolve this. hope some one else helps you mate I am too busy atm and do not seem to have the energy to think about this.
good luck anyway mate
Old   May 18, 2015, 23:32
Dhayananth
Thank you Shereez for your reply.
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
Multiple Fluid Zones Naghman Khan FLUENT 3 August 3, 2007 07:23
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
surface-creation on 1 of 2 overlapping fluid zones Volker Pawlik FLUENT 0 November 17, 2000 05:15
