April 16, 2015, 16:00 |
decreasing computational domain
Aja
Rep Power: 14 |
I am modeling a wells turbine and I have a question. Turbine have 6 blades.((360/6)=60 deg=angle between blades) Due to the circumferential symmetry, only one sixth of the annulus has been computed, imposing periodic boundary conditions in the tangential direction. The computational domain has been restricted in the axial direction to six chord lengths upstream and ten chord lengths downstream of the blade. Fig. 1: Now, we can to decrease angle(fig. 4) until computational domain reduce. Is this work true? For example, instead of angle of 30 deg, we use angle of 20 deg until computational domain reduce.Is this work true? With performing this work, Are solutions of analysis good in fluent? Fig. 2: Fig. 3: Fig. 4: Fig. 5......((30 deg))) Fig. 6: |
April 18, 2015, 14:02 |
Aja
Rep Power: 14 |
Can no one guide?
April 20, 2015, 01:15 |
Maxime Perelli
Rep Power: 41 |
If your geometry looks like the one in fig 2; then the only solution for decreasing computationals cost is your figure 3.
Indeed by apllying periodicity you can afford to compute your domain with 360/6 = 60° slice. I you use fig. 5 with 30° slice, and you apply periodicity, then you are computing 360/30=12 blades turbine
In memory of my friend Hervé: CFD engineer & freerider |
Domain Imbalance | HMR | CFX | 5 | October 10, 2016 05:57 |
Multi-phase free surface ship flow computational domain size | kilroy | Main CFD Forum | 0 | December 20, 2013 09:41 |
Pressure fluctuation in whole external-flow computational domain | lordvon | OpenFOAM | 0 | January 26, 2011 08:47 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
[blockMesh] Solid volume inside computational domain | francois | OpenFOAM Meshing & Mesh Conversion | 7 | November 19, 2008 16:11 |
