[ICEM] "Mesh has uncovered edges. ANSYS Fluent needs a complete boundary" |
May 24, 2015, 07:39 |
Rep Power: 11 |
Hi,everyone.
I have a problem with meshing by ICEM CFD. I'm blocking a 2D geometry in ICEM and then meshing & converting it to uns mesh, but when i try to export it for ansysfluent one error as follow appear. "child killed: SIGABRT WARNING: Mesh has uncovered edges. ANSYS Fluent needs a complete boundary (lines in 2D) or it will give a variety of errors and not read in the mesh! If this was 2D Hexa, perhaps your edges are not associated with perimeter curves". I try too much to solve this problem,but i can't. Please told me how i can solve this problem. Thanks. |
May 24, 2015, 11:42 |
Rep Power: 11 |
I did it (associate edge to curve) several time, but this error appeared again. Now i don't know what should i do?
May 24, 2015, 14:11 |
Rep Power: 11 |
sure.
Please take a look and told me your opinion. Thanks. |
July 7, 2016, 04:38 |
#7 | |
Przemek
Rep Power: 15 |
I had the same problem and then I associated curves to edges and it solved the problem.
best regards pblasiak |
August 10, 2016, 14:52 |
Hussein
Rep Power: 9 |
Hi guys, I am wondering if you solved the error you faced? Actually, I am using ICEM to create a mesh for my airintake geometry and I faced same error (warning), this error says "the mesh has uncovered edges", please help....
August 10, 2016, 16:19 |
#9 |
Przemek
Rep Power: 15 |
Hi
you have solution in the previous post
August 10, 2016, 16:25 |
#10 |
Hussein
Rep Power: 9 |
The edges and curves have been associated, but the problem keeps on....
August 11, 2016, 02:49 |
#11 |
Przemek
Rep Power: 15 |
3D or 2D mesh?
August 14, 2016, 09:38 |
#12 |
Hussein
Rep Power: 9 |
It's 2D mesh.
August 15, 2016, 16:17 |
#13 |
Przemek
Rep Power: 15 |
Ok. I have also met this problem in the 2d mesh. I fixed it by using Check Mesh tools.
ICEM will ask you if to delete some edges, so then choose ignore option. I hope it helps.
August 17, 2016, 09:26 |
#14 |
Hussein
Rep Power: 9 |
Thanks bro, it works...
September 20, 2016, 19:37 |
Same Issue no resolution
#16 | |
Akash Kumar
when I look at the "lines" of my mesh I notice that not all of the lines around my boundary have been included. However, I have associated the edge to curve for these parts and ICEM confirms the association but I still have the same error. I have looked at the "check mesh" which highlights a number of cells, however nothing has been resolved when I clock "fix". Please help. |
September 21, 2016, 06:31 |
#17 |
Przemek
Rep Power: 15 |
give fix wherever possible and ignore otherwise
September 28, 2016, 16:47 |
quality mesh
#18 |
ahmadeng
Rep Power: 9 |
Please i need help than anyone how to get a quality mesh good in fluent?
September 29, 2016, 06:07 |
#19 |
Przemek
Rep Power: 15 |
Hi
attach your files on the forum
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Commercial meshers] icem fluent mesh with cyclic boundary condition | jiejie | OpenFOAM Meshing & Mesh Conversion | 2 | February 24, 2020 03:34 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
