June 25, 2015, 23:40 |
The issue during mesh in GAMBIT
ziqi
Rep Power: 10 |
Hi everyone, I have some problem when meshing volume mesh by using GAMBIT.
I wanna mesh the space close to people face with 0.002 interval, and the space close to body 0.01 interval and other with 0.05 interval. In the attachment, I need to mesh the internal volume (the onehas tiny ventilation inlet) with very density mesh. My problem is I could not use submap directly mesh the small interval area. And the system is out of dynamic memory by using Tgrid. So it suppose use submap faces and copper that to volume, right? What kind of procedure should I use? mesh-quad-faces(which faces?)--copper--hex/wedge--source(which faces?) I am not familiar with copper. Which face should I mesh and using which source to copper. Thank you so much Last edited by UNL learner; June 26, 2015 at 17:07. Reason: add figure |
June 26, 2015, 02:24 |
Maxime Perelli
Rep Power: 41 |
it sounds you want to mesh your domain in one shot.
You will have to split your domain and mesh critical "space" separately. Do you have a picture of your model?
In memory of my friend Hervé: CFD engineer & freerider |
June 26, 2015, 17:09 |
reply to mAx
ziqi
Rep Power: 10 |
Hi mAx,
I added the figure and you could see it in my post. Thank you so much. |
June 29, 2015, 01:47 |
Maxime Perelli
Rep Power: 41 |
I confirm: you have to split your domain
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
3-d mesh gambit (cylinder within a cylinder) | Jason | ANSYS Meshing & Geometry | 29 | October 30, 2015 08:59 |
Gambit - Mesh Problem for a complex 3D geometry | Nelson | FLUENT | 3 | May 28, 2012 06:57 |
Moving Mesh Velocity Issue: Mesh velocity does not equal displacement | Doginal | CFX | 2 | September 8, 2011 12:02 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
