[ANSYS Meshing] Negative element quality but no negative elements
Old   July 2, 2015, 12:32
Default Negative element quality but no negative elements
Shruti is on a distinguished road
Hi everyone,
When I checked my pre-mesh quality today, it showed 1 negative value, -0.094, but no negative elements. I am unsure what to make of this, and how should I get rid of negative quality in such a case?
I also checked the quality for unstructured mesh, and I got the same quality histogram.
Shruti is offline   Reply With Quote
Old   July 2, 2015, 18:54
Kapi is on a distinguished road
Hi Shruti,
Find out which part of your geometry has bad quality elements first, then use Sizing or any other way which suits your geometry and create a better mesh around that region.
This should solve your problem.
Cheers
KAPI
Kapi is offline   Reply With Quote
Old   July 3, 2015, 07:31
Actually, my geometry has about 3-4 sensitive regions which are problem areas. How would you suggest finding out which area has these negative values in such a case? When I had negative elements, I could simply click on them and find out.
Old   July 9, 2015, 01:27
Hi Shruti,
Since you know there are 3-4 sensitive areas then tackle those areas and try to get best mesh possible in those area.
Once you have mesh, check if you are still getting negative value.
Even if you were not getting negative value, I would have suggested you to have good mesh around sensitive area, it gives you more accurate result.
Cheers
KAPI
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 10:51
[ICEM] Eliminating Negative Volume Elements Josh ANSYS Meshing & Geometry 16 July 9, 2014 13:01
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[ICEM] Hex refinement negative quality afterwards Anorky ANSYS Meshing & Geometry 8 March 22, 2010 03:25
Negative quality elements in ICEM Grid Kartik CFX 2 June 17, 2005 04:45
