July 8, 2015, 09:39 |
filter/strainer/porous media
afsaneh
Rep Power: 11 |
hello all
i need to investigate pressure drop in a filtration(porous) media for solid/liquid/gas separation. but before analyzing this study i should make the geometry and mesh of the porous media in gambit. can any body help me about this field in gambit. thanks. |
July 9, 2015, 01:19 |
Maxime Perelli
Rep Power: 41 |
2 choices:
*you build and mesh your porous media (you have geometric model) *you assign a simple region as separated fluid domain, and set it up as porous media
In memory of my friend Hervé: CFD engineer & freerider |
July 9, 2015, 03:53 |
Re:
#3 | |
afsaneh
Rep Power: 11 |
thank you for your help, but I don't know how I can do it?! for example I define a cylindrical geometry in gambit and want to define porous zone in its sidewall (not its top and down wall) for separating solid particles larger than for example 100 micron. can you please help me how can I define it in gambit or ansys fluent (in fact I don't know how defining porous media) thank you. |
July 9, 2015, 04:16 |
Maxime Perelli
Rep Power: 41 |
Once your geometry is done, you can select your faces or volumes and specify what kind of continuum it will be
It is just a way for treating this domain separately later in the solver (so you will have to specify you porous parameters in fluent and not in gambit) https://www.sharcnet.ca/Software/Gam...zone_cont_type
Multiphase Porous Media Flow - Convergence Issues | VT_Bromley | FLUENT | 7 | May 14, 2020 16:34 |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 10:34 |
Two phase flow in porous media | Madhavi Krishnan | FLUENT | 3 | June 6, 2005 05:52 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 15:16 |
