January 30, 2013, 08:33 |
problem with the mesh
yahya
Rep Power: 13 |
I tried to generate a mesh for considerebly complexed geometry
but I got the following errors and warnings 1) Error: The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology. 2) Warning: The following surface or surface bounds may have incorrect orientation 3)Warning: The advanced size function failed to initialize the following topologies. 4)Error: A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible. can anyone help me in this regard? |
August 6, 2015, 08:19 |
did you find a solution to this problem?
August 6, 2015, 18:19 |
#3 | ||
Rep Power: 14 |
Cheers KAPI |
Dynamic Mesh Problem. | Tom Clark | FLUENT | 10 | June 21, 2021 04:27 |
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
Convergence problem when ustructured mesh is used. | SangJin Ryu | Siemens | 3 | October 5, 2000 20:26 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
