[ANSYS Meshing] Multibody refinement method problem |
August 18, 2015, 10:54 |
Rafal
Rep Power: 12 |
Hello guys!
I need a little help with meshing rather simple geometry for welding simulation problem. Here is geometry with partially created mesh: It consist of 4 bodies grouped in one part. I need to create dense mesh (1e-5m or smaller, prefered hexa) within orange and green region and sparse mesh on the wide parts. I've trying to create sizing definition in the "path" regions but results are not satisfactory. I'm at best just an intermediate user of Ansys Meshing module so possibly there is some easy method to obtain desirable result. |
August 18, 2015, 18:38 |
Rep Power: 14 |
Use sizing function with Behavior>Hard and give your element size.
Mesh Refinement Study Problem | lde5047 | Main CFD Forum | 3 | August 6, 2014 07:22 |
[snappyHexMesh] SnappyHexMesh not enough refinement | simplefoam | OpenFOAM Meshing & Mesh Conversion | 2 | August 30, 2013 03:37 |
New Cutcells method Ansys 13 symmetry problem and doubt | William D Acosta | ANSYS | 1 | June 8, 2011 10:33 |
Panel method problem | niavarani | Main CFD Forum | 1 | June 17, 2003 10:01 |
a problem about pressure correction method | tommewang | Main CFD Forum | 2 | May 15, 2003 21:18 |
