[Workbench] Boundary Layer mesh on airfoil by CFX |
August 29, 2015, 13:52 |
mamly
Rep Power: 15 |
Hello friends
I am trying to mesh an airfoil by CFX workbench. As you know boundary layer is so important for airfoils. But I dont know how can I generate boundary layer by workbench, is anybody familiar with that? And can you send me a tutorial or an example? Thanks guys |
August 31, 2015, 02:35 |
Maxim
Rep Power: 12 |
Why don't you check out the tutorials provided by ANSYS first?
Are you planning on a steady-state or transient calculation? One approach could be to use inflation (also called prism layers) as Far suggested and then start with the SST turbulence model. You should check what y+ numbers you need depending on the turbulence model you want to use. |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
