[ICEM] H-block, Orthogonal Quiality, High Aspect ratio
Old   September 3, 2015, 01:38
Default H-block, Orthogonal Quiality, High Aspect ratio
jyh
jyh3134 is on a distinguished road
Dear,
I'm studying mesh generation for external simulation of wing-body.
The body has sharp LE, TE and wingtip, so I have no choice without
H-H block.
The problem is, Fluent said orthogonal quality is less than allowable value, 0.01 while ICEM-CFD showing good quality(determin. > 0.8, angle>0.3)
I thinks this is due to very high aspect ratio in away from body(far field region), up to 100,000.
I copied edge parameter from near body to far field for uniform cells.
But some of this community said that some effot of setting each edges parameter respectively is need to have good quality.
I attached a picture to help understanding.
Best & Regards
jyh3134 is offline   Reply With Quote
Old   September 3, 2015, 11:35
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Can you attach a picture of the blocking, edge mesh parameters and value of Tgrid skew quality in ICEM
shereez234 is offline   Reply With Quote
High aspect ratio mesh problem for flat plate boundary layer sam1364 OpenFOAM 3 May 14, 2020 11:11
[ANSYS Meshing] high aspect ratio mhdmk ANSYS Meshing & Geometry 1 October 12, 2014 19:54
aspect ratio vs. y+ hammam CFX 3 August 6, 2007 10:41
High aspect ratio in viscous sublayer? Marius Main CFD Forum 0 December 22, 2005 08:15
high aspect ratio elements Olivier CFX 5 April 3, 2003 06:55
