[ICEM] Radial number of cells in cylinder
Old   September 4, 2015, 09:59
Default [Solved] Radial number of cells in cylinder
fst-student is on a distinguished road
I want to mesh a cylinder. I allready have the right geometry but if I want to set the number of cells in the radial direction the number doesn't change. For the horizontal and vertical direction all changes of the number of cells are accepted and shown if I recompute the premesh. Any changes in the radial direction seem to be ignored. I attached a screenshot so you can see the problem.
Has anyone an idea?
EDIT:
The case is solved. Only ICEM does not show the cells. I checked for the number of cells and if I increase the spacing the number of cells increases too. If I import the mesh into openfoam all cells are shown correctly.
Thank you
fst-student is offline   Reply With Quote
Decomposing meshes Tobi OpenFOAM Pre-Processing 22 February 24, 2023 09:23
Help compiling code (newbie) thsb20 OpenFOAM Programming & Development 56 August 24, 2016 04:24
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 18:45
[snappyHexMesh] problems using snappyHexMesh 2.1.0 on a supercomputer Sunxing OpenFOAM Meshing & Mesh Conversion 9 September 20, 2014 09:30
