September 27, 2015, 09:55 |
How to Mesh propeller
Rep Power: 13 |
Hi all,
I need to carry out anaysis on APC propeller. The test bed will be causing flow upwards towards the ceiling of the room (3m * 3m) which would be atleast 2 meters higher than the prop plane. The RPM range for test conditions maybe 3000,7000,8530 RPM. I came across some doubts regarding meshing 1. Do I treat propeller as airfoil? 2. there is a hole at the center of the propeller, how to mesh it? I'm struck Any help would be appreciated |
September 28, 2015, 13:14 |
Rep Power: 13 |
This is the propeller image.
September 30, 2015, 08:04 |
Maxim
Rep Power: 12 |
1) yes, you can treat the propeller as an airfoil.
2) do you need that hole in the middle for your simulation or can you just ignore it? You could only mesh one blade and then set up a periodic simulation with the second blade being a copy of the first but turned 180 degrees. Do you have TurboGrid in your workbench? I use that to mesh my blades. |
September 30, 2015, 11:00 |
Rep Power: 13 |
Thanks for the reply.. I don't need that whole anyway. Do I need to cut that blade into half and treat as a wing??... Please help.
September 30, 2015, 11:01 |
Rep Power: 13 |
I have turbogrid in workbench
October 5, 2015, 02:21 |
Maxim
Rep Power: 12 |
I would suggest you do the TurboGrid tutorials. Then you will know how the 'exportPoints' feature works (Hub, Shroud, Inlet, Outlet lines) and can probably answer your questions yourself
October 5, 2015, 09:33 |
Rep Power: 13 |
Thank you. I'm on to that part
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
engrid -> save as .stl with boundarie codes | Zymon | enGrid | 31 | August 29, 2011 13:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
