October 14, 2015, 10:40 |
How to do hexahedral meshing
Priyanka
Rep Power: 10 |
The total number of hexhedral cells are 8400
The mesh sizes are variable and were 10-20 mm in z direction and 21-85mm in x direction and 8-10mm in width Please help me Thank in advance |
October 14, 2015, 11:14 |
#2 | |
Frank Weise
Rep Power: 17 |
Hello Priyanka
So i could wrote: If the mesh size 10mm x 21mm x 8mm, your body has a volume of approx 14.1L and you have to take 20 elements in z, 14 elements in x and 30 elements in y. Or you have to take 12 elements in z, 20 elements in x and 35 elements in y. etc... regards Frank |
October 14, 2015, 11:35 |
#3 | |
Priyanka
Rep Power: 10 |
the above images are domain and mesh which should be created the size of the mesh is variable and the details of the mess size are mentioned above sorry for incovenience thank you Last edited by Priyanka Konakandla; October 14, 2015 at 12:55. |
October 14, 2015, 12:47 |
Frank Weise
Rep Power: 17 |
I don't see any image above! Edit: Image now available.
Last edited by FrankW; October 15, 2015 at 02:42. Reason: Change of previous post |
October 14, 2015, 23:33 |
Priyanka
Rep Power: 10 |
Please some one look into this problem
October 15, 2015, 02:43 |
sluzzer
Rep Power: 11 |
This you can do in ICEM cfd only... In icem cfd u can set the no. of nodes and spacing on each edges...
In ansys meshing you don't have that control |
October 15, 2015, 02:50 |
Priyanka
Rep Power: 10 |
Hello sir,
My assignment in is to replicate the results of a journal They mentioned that they used ansys cfx code Thank you |
October 15, 2015, 02:56 |
Frank Weise
Rep Power: 17 |
I don't understand your problem.
You have to generate a simple body, maybe in DesignModeler. And than the body must be meshed with Ansys meshing or icem. There, the mesh size can be adjusted as desired. Maybe you should look at the Ansys Help and Tutorials to. regards Frank |
October 15, 2015, 03:01 |
#9 |
Frank Weise
Rep Power: 17 |
October 15, 2015, 07:30 |
#10 |
sluzzer
Rep Power: 11 |
Ansys cfx is for setup and analysis... Ansys meshing and ICEM CFD are for meshing... Previous there was cfx meshing.. Now it's not there I think
October 15, 2015, 07:37 |
#11 |
sluzzer
Rep Power: 11 |
Frank,
Priyanka needs specific no. of elements on each side.. Its not possible to explicitly define it in ansys meshing... We can control only indirectly through max element sizing.. |
October 15, 2015, 08:21 |
#12 | |
Frank Weise
Rep Power: 17 |
October 15, 2015, 09:02 |
#13 |
sluzzer
Rep Power: 11 |
Oh ok there are no. of divisions option.. I was not knowing this
October 15, 2015, 09:42 |
#14 |
Priyanka
Rep Power: 10 |
Thank you soo much sir
October 15, 2015, 10:06 |
#15 |
Rep Power: 18 |
October 16, 2015, 02:49 |
#16 |
Frank Weise
Rep Power: 17 |
October 16, 2015, 05:44 |
#17 |
Priyanka
Rep Power: 10 |
i am sorry sir, i encountered some problems while meshing because of some mistake committed in design modeler
how did u calculate the number of divisions while edge sizing? |
October 16, 2015, 05:45 |
#18 |
Priyanka
Rep Power: 10 |
i am sorry sir , i encountered some issues while meshing because i creates some extra surfaces in design modeler
how did u calculate the number of divisions in sizing? |
October 16, 2015, 06:04 |
#19 | |
Frank Weise
Rep Power: 17 |
If that was causing problems, you should not play with CFD! |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[CAD formats] Hexahedral meshing of CAD files - Which free software? | Wolle | OpenFOAM Meshing & Mesh Conversion | 14 | November 22, 2014 21:40 |
[ICEM] Subdomain meshing and simple Hexahedral Grading | Mojtaba.a | ANSYS Meshing & Geometry | 0 | April 22, 2013 13:28 |
[ANSYS Meshing] hexahedral meshing of assemblies: Limitation of ICEM? | moisedion | ANSYS Meshing & Geometry | 2 | February 28, 2013 09:48 |
hexahedral meshing of assemblies: Limitation of ICEM? | moisedion | CFX | 1 | February 27, 2013 16:50 |
