November 25, 2015, 08:36 |
Topology-error
Konstantin Zitrus
I am trying to mesh the fluid volume of a radial compressor with turbogrid. After preparing the hub, the shroud and the blade geometry of main-blade and splitt-blade with the Ansys Design Modeler, I wanted to mesh the volume in turbogrid. The geometry seems to be loaded correctly, but the topology fails with the following Error: ERROR An error was thrown while generating the span geometry for Topology. This probably means the selected topology is not appropriate. Details are given below: U value outside ot its bounds. Value =-0.243 How can I solve this problem? Thank you for your answers. |
November 27, 2015, 04:44 |
Maxim
Rep Power: 12 |
I think I had a similar error before. In my case, part of my blade was cutting through in the inlet/outlet interface of the TurboGrid.
So I would suggest you double-check the geometry (location of inlet/outlet/hub/shroud) - maybe give the TG mesh some more space around the blade. It would maybe also help to post a screenshot of your geometry in Ansys Design modeler |
May 29, 2016, 17:26 |
Hossein
Rep Power: 9 |
I'm trying to mesh a radial turbine (with splitters) Using TurboGrid, I have exported the geometry of blades and splitters using Design Modeler via two separate ExportPoints features for blades and splitters. Here is where I'm stuck: 1. When I try to mesh the turbine with both blades and splitters, I get the same topology error which is discussed in this topic. 2. I can mesh a turbine with just blades, or just splitters which seems to mean that the curves don't have any problems and topology constraints is the cause of error. 3. I changed the the place of leading edge and trailing edge and meshed the geometry as a centrifugal compressor, this resulted to a nice mesh without even a warning! Is it possible that I use the compressor mesh and correct it by boundary conditions in the next step? Would this effect the validity of results? |
March 4, 2020, 08:59 |
Brett
Rep Power: 13 |
Hey all,
Any resolution to this? Im trying to add a second splitter to a compressor model and that seems to be triggering the error the first poster described/. |
September 21, 2020, 23:51 |
Andreas Sun
Rep Power: 13 |
try change the rotation direction, it works on my cases sometimes.
July 25, 2023, 15:51 |
Weiqiang Zhao
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 17:38 |
