[ANSYS Meshing] problem with updating mesh in fluent module |
December 16, 2015, 03:51 |
I am doing a simulation using ANSYS FLUENT 14.5 of effect of wind load on the cross section of pentagonal building. Inlet velocity is 13.5 m/s with various angle of attack like 0,9,18,27,36,45,63 degrees. But after crossing 27 degrees, I have found reverse flow. So, now most probably I have to increase downstream computational domain and outlet meshing properties like face size, fineness. But when I update meshing properties and go to fluent there are several error messages like " Cannot change surface_body to fluid. They are different kinds." "zone surface:invalid thread[2]" "cx-restore: no views are restored" Can anyone please help me through these? Thanks. |
December 17, 2015, 06:28 |
Rep Power: 13 |
For the surface body part, make sure the body type is fluid and the mesh generated is for CFD not mechanical.
For the reversed flow, it is only information that fluent is giving, there is nothing wrong in having reversed flow, it is not an error. |
December 17, 2015, 10:56 |
#3 | |
Thank you so much for your help. |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
Problem with 2D ICEM mesh check in fluent | Nicola | FLUENT | 3 | March 25, 2013 05:56 |
Problem with updating of mesh! Help!!! | Faby | FLUENT | 1 | July 4, 2012 03:12 |
