December 20, 2015, 15:41 |
2-pipe intersection
Ali Reza
hi
I want to mesh a 3D 2-pipe, but I have a problem for this work, after creating 3 cylinders in +y,+x, and -x coordinates, I unite them, then I create a sphere with the same radius of cylinders, then I unite these two volumes, then I want to create 3 volumes that are look like cylinders in order to mesh them with a structural mesh. there is a similar work in the tutorial, as written in tutorial, I should create an edge,then create 3 faces, and then split my volume with each face in order to create my desired 3 volumes, but after splitting my volumes, I encountered a problem my figure should be like these picturesfigures:Sans titre, and 2 pipe intersection) but my work was like thisfigures:1, 2 , and 3) please help me |
January 4, 2016, 01:13 |
Maxime Perelli
Rep Power: 41 |
I don't see any purpous of using the sphere, so forget it.
From your picture 2, you should achieve your work, by splitting the volumes into 3 separated volumes (you may use the 3 surfaces like your face.15)
In memory of my friend Hervé: CFD engineer & freerider |
[DesignModeler] DesignModeler Pipe within pipe | shields | ANSYS Meshing & Geometry | 13 | November 25, 2018 22:14 |
[GAMBIT] 3D mesh for pipe intersection | pranab_jha | ANSYS Meshing & Geometry | 3 | May 28, 2010 01:33 |
meshing at a pipe intersection | cyn | FLUENT | 0 | December 20, 2006 02:16 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
