December 27, 2015, 08:41 |
Problem with face meshing
BIANCA GIAROLA
Rep Power: 10 |
I'm working on 2D airfoil simulation and I had some problems with the mesh . I tried use the face meshing , but it worked in only 2 of the 6 selected faces and I do not know why it happened . Does anyone know what to do? Thanks |
December 30, 2015, 05:47 |
Rep Power: 13 |
post pictures and setup details
January 5, 2016, 07:06 |
BIANCA GIAROLA
Rep Power: 10 |
I took some prints of the mesh and setup. I divided
the mesh into 6 parts , but face meshing worked only in two of the 6 parts. |
January 5, 2016, 20:05 |
Rep Power: 13 |
err, cant see the pictures...
OK i see them now. From what i understand you think that face meshing will give you a hex mesh? No, it wont. There are quite a few tutorials for aerofoils you can find on the internet, try going through a few of them. The geometry is an aerofoil is it? Or you can just use a tet mesh with inflation on the aerofoil surface it will give you good results too. Look at leap blog on inflation layer and y+, it has got good explanations. if you cant find it let me know i will post the links here later then. |
January 8, 2016, 06:45 |
BIANCA GIAROLA
Rep Power: 10 |
I watched this tutorial https://www.youtube.com/watch?v=LAIB7qK-9pE for make the mesh but the images show the results and it is not the same of the tutorial and I don't know why
face meshing 2d airfoil |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
Problem with dynamic meshing in 2D | bhargavbharathan | FLUENT | 3 | November 18, 2015 11:58 |
[ANSYS Meshing] Mapped Face meshing | Thermal_engg | ANSYS Meshing & Geometry | 4 | June 5, 2013 05:37 |
[GAMBIT] Meshing problem | nkme2007 | ANSYS Meshing & Geometry | 1 | December 5, 2012 08:29 |
[GAMBIT] fac meshing problem, not skewness | bugra | ANSYS Meshing & Geometry | 0 | September 3, 2010 07:40 |
