[TGrid] [Fluent Meshing] Airfoil surface mesh |
January 9, 2016, 13:36 |
Lukas
Hello everyone, I am trying to get CFD analysis for my Formula Student team started. I visited a course held by Ansys on CFD with Fluent meshing and Fluent, but unfortunately they didn't talk about CAD import to meshing. My problem is:
I want to import a simple airfoil geometry (for starters, as I get the same problems with bigger wing assemblies) and simulate it. But I fail at the surface mesh. I take the CAD geometry made in Solidworks and import it to DesignModeler, there build an enclosure and subtract the wing to get the fluid volume, and then import it to Fluent Meshing. Using CAD faceting for the import, I get the following horribly skewed surface mesh: Using CFD-type faceting with min size = 0.01, max size = 1 and a default curvature angle of 10, I get this mesh: The triangles are looking good, but there are some missing at tip and end of the wing. If I set a smaller minimum size (f.e. 0.005 instead of 0.01), conformal tesselation fails on the wing area. So my question is: Is there a way to get a proper surface mesh to use with this very simple problem? I don't want to imagine what problems I will encounter when I get to import the whole car... Thanks in advance! Kind regards, Lukas Last edited by rndmplyr; January 9, 2016 at 15:11. |
June 19, 2018, 11:05 |
majid fahim
Rep Power: 8 |
i have a similar problem with meshing a wind turbine blade
can anybody help |
Display Modes | |
[ICEM] Surface mesh not sticking to surface | holtwong | ANSYS Meshing & Geometry | 2 | April 20, 2023 09:28 |
[snappyHexMesh] Multi Region Mesh of a car filter | Zephiro88 | OpenFOAM Meshing & Mesh Conversion | 3 | September 11, 2019 20:34 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 08:05 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 05:24 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
