January 8, 2016, 11:53 |
[Gambit] - Concentric cylinders
karim
Gambit 2.4 - Mesh Problem
how to mesh 2 cylinders concentric? thx for help Image: https://plus.google.com/u/0/11521771...19125756046678 Last edited by wyldckat; January 9, 2016 at 12:04. Reason: fixed broken link |
January 11, 2016, 01:25 |
Maxime Perelli
Rep Power: 41 |
split big cylinders with small cylinder.
keep the small cylinder if you need it. Then you can go and mesh
In memory of my friend Hervé: CFD engineer & freerider |
January 11, 2016, 11:24 |
karim
thanQ you MAX that you reply
i do creat 2 cylinders concentric i just have problem i have ,its to mesh the volume between this 2 cylinders thanq again |
January 12, 2016, 01:10 |
Maxime Perelli
Rep Power: 41 |
do you have the annular volume or still both cylinders (as volume)?
How many volumes do you select, if you select all the entitis?
Display Modes | |
Problem with building geometry - concentric cylinders | Rhoddwen | OpenFOAM Pre-Processing | 9 | December 17, 2014 10:02 |
Problem with geometry - concentric cylinders | Rhoddwen | OpenFOAM Running, Solving & CFD | 0 | December 15, 2014 09:22 |
[DesignModeler] split into concentric cylinders | kmgraju | ANSYS Meshing & Geometry | 1 | March 5, 2013 14:10 |
Flow Between Concentric Cylinders | larscliff | ANSYS | 0 | February 17, 2011 04:43 |
[GAMBIT] Dynamic mesh for concentric cylinders | mijama | ANSYS Meshing & Geometry | 1 | October 20, 2009 01:58 |
