[ICEM] how to set solid and fluid region
Old   January 14, 2016, 05:14
Default how to set solid and fluid region
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Dear friends:
I meshing a " serpentine channel in a box " problem, it is a conjugate heat transfer problem.
I have split the block as shown in the attachment.
But how to define the solid region and the fluid region.
I have defined the material point , but fluent merge it all to a single region.
Regards
ztdep is offline   Reply With Quote
Old   January 14, 2016, 05:47
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
If you have defined the material points in the solid and fluid regions you should also create 2 distinct parts with the respective block for both regions (fluid_blk and solid_blk). Then you can specify which type of volume is assigned to your fluid and solid region under the output mesh tab > boundary conditions > Volumes and you'll see the fluid and solid volumes.
When you import it in fluent you'll have both regions:
Gweher is offline   Reply With Quote
Old   January 14, 2016, 07:08
ztdep's Avatar
p ding
thanks , your fluent gui is very similar to cfx. which version are you using?
Old   January 14, 2016, 08:19
Gweher's Avatar
Gwenael H.
I'm using version 16.0 of fluent, I also checked on an older version (15.0) and it's the same procedure.
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 00:37
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 02:23
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
