[ICEM] Various errors in importing geometry
Like Tree3Likes
  • 1 Post By PSYMN
  • 1 Post By Omerta
  • 1 Post By eakpink
Old   May 17, 2011, 10:00
Default Various errors in importing geometry
Iceman is on a distinguished road
Hi everybody, i just need your help.
I know the problem could be banal, but i can't get out of it.
So, I just passed from Ansys 11 to 13, and immediatly I had some problems with Icem.
I'm trying to import a Parasolid geometry (x_t) (tried to create it by using different modelers, as SolidWorks, Ansys DesignModeler), gave the .tin file the same directory of the Parasolid file, but when importing Icem says: The tetin file aaaaa.tin does not exist.
So, I tried to import an IGES file too, but after the creation of the .tin file Icem says: can't read surface model.
I really don't know what to do, I tried many times but never obtained some results.
I hope someone can find a solution for my problem, thanks.
E.C.
Iceman is offline   Reply With Quote
Old   May 18, 2011, 11:50
Default write permissions?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Sorry, not enough info. Parasolid import works for me.
Usually this sort of issue is due to ICEM CFD not having write permissions in the folder. The converter can't put the tetin file in the folder, so it doesn't find it for the import.
Simon
Iceman likes this.
Please help guide development at ANSYS by filling in these surveys
Public ANSYS ICEM CFD Users Survey
This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)...
CFD Online Users Survey
PSYMN is offline   Reply With Quote
Old   May 18, 2011, 19:25
Inspired by your suggestion I tried to load the file from different directories, and in some of then Icem can write the tin file and then load it.
It's a bit strange because I don't remember I set particular permissions to folders, however now it works.
Sorry once more for the banality of the question, but your post gave me the help I needed
Thanks.
Old   May 26, 2011, 01:46
Default Write permission error
Mohammad Naim
Mohd200 is on a distinguished road
Hi guys,
I am new to the whole CFD environment and often when I try to import geometry from solidworks (parasolid format) into ICEM a write permission error comes up. it goes something like this:
An internal error has occured:
could not read "./fairing and wheel.tin": permission denied
you can report the error to the maintainers of this software, skip the error and continue working, or view a stack trace.
Now, when i click continue i don't see any geometry getting imported. This does not occur all the time which is why i am puzzled. Is there a problem with the way i am saving the file in solidworks? How do i fix this problem? Any help would be much appreciated
Cheers
Mohd200 is offline   Reply With Quote
Old   May 26, 2011, 06:11
Vijaya Sekhar Gullapalli
gullapallivijay is on a distinguished road
Parasolid import into ICEM is not free in v13 as it is in v11. Your need to have one paralsoid import license to ICEM that is not relatively inexpensive. You can however translate the agdb file from design modeler to ICEM via CFX mesh.
gullapallivijay is offline   Reply With Quote
Old   May 27, 2011, 22:31
PSYMN's Avatar
Simon Pereira
Acis (*.sat) is free in ICEM CFD, can you output that from Solidworks?
Old   May 30, 2011, 04:11
Yes it's possible!
Old   December 9, 2011, 15:01
Kyle
Omerta is on a distinguished road
Originally Posted by Mohd200 View Post
Hi guys,
Cheers
I had that same issue, changing the working directory to the folder at hand worked for me.
Al-Hashimi likes this.
Omerta is offline   Reply With Quote
Old   July 17, 2012, 05:37
abdul
eakpink is on a distinguished road
thank you omerta i had the same issue.just i chenged my working directory to my hand it works now.
eakpink is offline   Reply With Quote
Old   January 20, 2016, 10:42
Default Update
Bruno F. Porto
brunofporto is on a distinguished road
I know this discussion is old but I had this problem and the solution and cause are different from the examples here.
In may case the problem was because of the file name of the imported geometry that had an speacial caracter: peça1.igs
When I exported (from SolidWorks) to a file name without the "ç", in this example "peca1.igs" this problem was gone.
Thank you for the help as it helped a lot to solve this issue.
brunofporto is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
