[Workbench] importing a 2D geometry into geometry modeler
Old   January 26, 2016, 23:01
Default importing a 2D geometry into geometry modeler
Jiyuan Kang
kjy1989 is on a distinguished road
Hello All
I'm doing 2D fluid analyses on a nozzle with a varying shape. In order to switch shape parameters fast (such as size of inlet and outlet, radian of nozzle wall, etc) I would like to make 2D drawings using solidworks (or autoCAD) and import the 2D geometry into ansys workbench and mesh it directly. However, ansys is keep showing me "attach failed" error message. I tried different format and also changed setting in CAD configuration manger but still not working.
Has anyone got similar problems? Are there any way I can import a 2D geometry from outside?
Thanks for any help!
kjy1989 is offline   Reply With Quote
Old   January 26, 2016, 23:22
Kapi is on a distinguished road
same question has been asked many times. Please go through them and if you still dont have answer then come back and ask!
Kapi is offline   Reply With Quote
Old   January 26, 2016, 23:55
Jiyuan Kang
Thank you for reply. I actually read several thread with similar problems. The issue is, I have defined the geometry modeler to do 2D analyses, but there are still error messages coming out. I really just want to import very simple 2D .SLDPRT files (should be simpler than most of the other problems about geometry import).
Old   January 27, 2016, 11:16
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Kapi is right, there are a ton of posts related to this topic, I especially answered the exact same question not longer than 2 weeks ago :
http://www.cfd-online.com/Forums/ans...r-meshing.html
It is not only a problem of setting the analysis type to 2D, you also need to create your 2D sketch in the XY plane.
Please use the search function and dont just tell that you didn't find the answer because this topic has been treated a 1000 times.
Have a nice day
Gweher is offline   Reply With Quote
Old   July 28, 2017, 06:23
Cool import external geometry file in ansys workbench from auto cad
optimus prime is on a distinguished road
https://www.youtube.com/watch?v=-Y1NWiZbbZY
https://www.youtube.com/watch?v=Y8VtWAXL5-U
I have shown how to make a geometry in Auto-CAD and import it in Ansys Workbench.
optimus prime is offline   Reply With Quote
Old   July 29, 2017, 22:12
Jiyuan Kang
Thanks man, did u tried to use Solidwork? (When I posted this question I don't have access to AutoCAD) I posted this question last year and only received some non-useful reply, I did try many methods obtained from the previous discussions in this forum and none of them is working so I finally gave up and used the draw tools provided in ANSYS. I'm done with this question already but I'm still interested in knowing how to import 2D geometry from solidwork into ANSYS.
Old   July 29, 2017, 23:10
@kjy1989 sorry! I don't use Solid works. I use Auto cad for making geometry. If you use Auto cad, follow my video. I have shown how to import.
Old   July 30, 2017, 05:37
NISHANT
nizhantiw is on a distinguished road
Hey Kjy1989 you are importing a part file (SLTPRT)as you have mentioned, Sorry to say but Ansys doesn't import part file whether it's from CATIA or SOLIDWORKS . Save it as IGES or STL.
Alternative: You can go to the sketching option in design modular of Ansys an go to construct point create the required point and constrain them with desired dimension the connect the points with line now you have developed your nozzle
Is this helpful???
Sent from my Tab2A7-20F using CFD Online Forum mobile app
nizhantiw is offline   Reply With Quote
[ANSYS Meshing] Importing Geometry for analysis in Ansys AQWA AlexK ANSYS Meshing & Geometry 1 October 29, 2017 09:19
Importing geometry to ANSYS/ Meshing & Geometry Ttormuz ANSYS 1 January 26, 2016 01:18
Issues Importing Geometry (Hyperloop Design) iiwolf ANSYS 1 December 2, 2015 18:25
Problem Regarding Importing Carbon Nanotube Structure IN design modeler rhythm_saini ANSYS 0 July 4, 2012 03:34
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
