February 12, 2016, 10:23 |
3D meshing problem
Rocio
Rep Power: 10 |
Hello, i'm meshing a dam, block by block, and i would like to have a unstructured mesh in two orthogonal directions (attached image drawing in yellow) but i'm having some problems in the inclined border(attached image drawing in red). I unassociate all the vertex to the points and edges to lines. Thank you!.
February 15, 2016, 00:03 |
Rep Power: 13 |
trying making a block along the slope. a big one going from the top to bottom of the slope.
February 15, 2016, 13:24 |
refine density
Rocio
Rep Power: 10 |
Thank you so much, it worked well. But now i have another problem i want to refine (increase) the mesh density after the crest, but when i do it, there are nodes that are not connected. if there any command to do the transition (as in yellow in the image or similar)?. Thank you
February 15, 2016, 18:44 |
Rep Power: 13 |
Is it one body or two different bodies?
February 17, 2016, 09:58 |
Rocio
Rep Power: 10 |
February 17, 2016, 19:25 |
Rep Power: 13 |
Yes exactly so how does ICEM know that you want it to be one body?
I am not sure how to do it in ICEM, i mesh in ansys meshing, but you need to combine the two bodies into one part, that way ICEM will know that there are two bodies but you want the meshing to be conformal. I would suggest that you just do the meshing in Ansys meshing instead that will save you a lot of time. |
February 18, 2016, 09:39 |
Rocio
Rep Power: 10 |
Thank you, i will try.
Problem with querying the meshing database in CFX-Pre | ashtonJ | CFX | 18 | April 18, 2023 23:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 07:04 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
