[ANSYS Meshing] Pedestrian level wind simulation
Old   March 8, 2016, 20:59
Default Pedestrian level wind simulation
hemant mittal
hemmt is on a distinguished road
how to simulate air flow around urban environment at pedestrian level, my point is how to use google earth data for meshing around urban environment
hemmt is offline   Reply With Quote
Old   March 9, 2016, 06:17
Harry Eggo
harry94 is on a distinguished road
Just doing a study in this right now and will give you a bit of info at how I've went about doing this.
  • Cad Mapper To Gain 2D (or maybe 3D depending on how lucky you are and if the location you are studying contains building height data) to extract the area of interest and import it to a CAD file
  • If you do not have any building height data, study google earth and use the streetview function to determine heights if you don't already have that info
  • For meshing, you have to determine the areas you are most interested in (i.e. where pedestrians are). In your geometry, I'd be looking at specifying different levels of fluid domains so a finer element size can be given to areas near building geometries
  • Scale Model (you might want to redo this stage later depending on your purpose/capabilities
  • Determine your physical set-up and simulate
  • Go back and look at y plus values and other measures of quality and refine and resimulate if necessary
Hope that helps
EDIT: I'd also advise that you do a literature review and try to properly understand what you are trying to do. Jumping into software is tempting but you've got to have a very good idea of what you are doing or else you could waste a bit of time and produce data that you don't really understand yourself.
harry94 is offline   Reply With Quote
[snappyHexMesh] meshing of very small patches in comparison with the overall geometry christos OpenFOAM Meshing & Mesh Conversion 3 December 17, 2014 16:55
[snappyHexMesh] Adding layers goes wrong with SnappyHexMesh Elise OpenFOAM Meshing & Mesh Conversion 1 April 22, 2013 02:32
shaft power versus RMP curve in wind turbine simulation zhenduan306 CFX 28 November 8, 2012 10:11
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
3D simulation of wind turbine in Yaw wind(in a lateral wind) mohammad Main CFD Forum 0 December 28, 2010 03:26
