[ANSYS Meshing] I have Meshing Problems Ansys 16
Old   April 21, 2016, 03:46
Default I have Meshing Problems Ansys 16
Leonard
Leocali is on a distinguished road
Hi... I'm a beginner in Ansys... and i can not generate a mesh in a very simple geometry (open channel). I have tried a about a 3 days to generate but it doesn't happen...
Some of the error are
One or more entities failed to mesh. The mesh of the bodies containing these entities may not be up-to-date. However, meshing might be successful on the other entities.
The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem.
The mesh generation did not complete due to poor quality elements or incorrect input. Please try meshing with another mesh method or different mesh options.
I really donīt know how to fix it... pleas help me :/
P.d... I apologize for grammatical errors, I speack spanish and i donīt know how wrong i wrote this...
Regards Leo
Leocali is offline   Reply With Quote
Old   April 21, 2016, 18:36
Kapi is on a distinguished road
Hi Leonard,
Welcome to CFD Online.
I suggest you to go thru some basic example first which are available in HELP section.
Learn what are the entities they are using and try to follow each step to get mesh.
Try to read about it as well.
Cheers
KAPI
Kapi is offline   Reply With Quote
ansys 16 fluent mesh
ANSYS 2D Meshing The Engineer 2014 ANSYS Meshing & Geometry 0 March 26, 2014 20:54
Help me to choose between Ansys Meshing, Fluent Meshing or ICEM ? pipolaki ANSYS 0 December 6, 2013 08:12
Using ICEM CFD to repair/edit ANSYS Meshing Kaaji1359 ANSYS 2 July 30, 2013 10:28
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Hexa Block meshes in ANSYS Meshing? siw ANSYS Meshing & Geometry 3 July 31, 2009 10:40
