[GAMBIT] Problem with meshing a volume
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   May 6, 2016, 06:46
Default Problem with meshing a volume
Анита
ASTRA095 is on a distinguished road
Help me, please.
I created geometry (furnace atomic absorption analysis) in Gambit.
I started to make the grid and the error occurred: "ERROR: TG mesh domain failed with error code1
ERROR: Tetrahedral meshing has failed for volume.
This usually caused by problems in the face meshes.
check the skewness of your face meshes and make sure the
face mesh sizes are not too large in areas of small gaps."
I created a new geometry, but the error remained.
I created the face of the grid, but the construction of the volume error.
I am newbie. Please, what is my fault?
Thank you.
ASTRA095 is offline   Reply With Quote
Old   May 9, 2016, 01:33
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you are trying to mesh a volume on the fly, but you have small entities in your geometry.
If you don't set any size function or whatever, Gambit will try to mesh the volume with the parameters you gave (and will fail because of small feature).
Check in your geometry where are small features, and use size functions
ASTRA095 likes this.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 9, 2016, 13:54
Анита
I ask for each face mesh. And then the total volume. There is also a negative volume of error. How to use the size functions?
Old   May 10, 2016, 01:29
-mAx-'s Avatar
Maxime Perelli
https://www.sharcnet.ca/Software/Gam...ommands_create
Old   May 11, 2016, 14:50
Анита
Thank you. Happened. I found a very small volume. I made a simple volume and the mtsh was created.
mesh volume
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 02:52
Gambit meshing problem to following geometry ahmadmln ANSYS Meshing & Geometry 2 October 21, 2014 01:49
Volume meshing problem Tensian enGrid 1 January 23, 2014 17:06
[ICEM] Meshing the Fluid Volume of a Fibrous Membrane/Media--Help with errors/settings? ANT ANSYS Meshing & Geometry 4 July 10, 2013 00:20
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
