[ICEM] ICEM automatically merging two separte parts |
May 9, 2016, 08:48 |
kasra
Rep Power: 10 |
hi all
I have a model of an air to air heat exchanger. basically there are two air streams which are separated by a copper foil of 0.01mm thickness. when I mesh the geometry in ICEM the software automatically considers the copper foil to be part of the cold air stream. so because of this problem when I import the mesh into CFX it is not possible to specify boundaries for the copper sheet. any suggestion would be appreciated. thanks in advance |
May 15, 2016, 20:13 |
Rep Power: 13 |
in CFX you can set the boundary as thin material, then select copper and thickness. No idea, if that works in ICEM. Plus you would have to make 2 domains. And I found (in CFX), you have to set an expert parameter, so its 2 different physics, otherwise both fluids would mix.
Found that is an heat exchanger, there are 2 different fluids I dont want to mix. Again, thats in CFX, not ICEM, but you may find something there. Separating domains was in Beta options. |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
ICEM mesh merging problem | Serge | CFX | 2 | October 22, 2007 06:13 |
merging edges in ICEM | Virag Mishra | CFX | 4 | August 24, 2007 06:06 |
Merging mesh elements in ICEM | Felix | CFX | 1 | May 9, 2007 10:33 |
ICEM CFD 5.1 Hex-Tet mesh merging failure | bogesz | CFX | 1 | January 29, 2005 06:46 |
