Home > Forums > ANSYS Meshing & Geometry
[ICEM] How to set periodic faces on a blocking of a blade
Like Tree2Likes
  • 1 Post By Far
  • 1 Post By McCharles
Old   May 20, 2016, 04:12
Default How to set periodic faces
Paurnamie Samarakone
Nat Sam is on a distinguished road
Hi everyone
I'm trying to mesh a blade on ICEM. I first need to set up peirodic faces.
You can see what my blocking looks like on the pics. The cylinder represents the hub on which the blades are fixed. I'm afraid I can't post a pic of my blades.
If I get it right, the faces I need periodic are indicated on the .pdf but I can't make them periodic... I don't understand which vertices to select.
If my blocking is incorrect, pls let me know.
Could you help me ?
Best rgds
Nat Sam is offline   Reply With Quote
Old   May 20, 2016, 10:33
Far
Sijal
Far will become famous soon enoughFar will become famous soon enough
Send a message via Skype™ to Far
faces on both sides of blade, in the direction of rotation, should be assigned as periodic.
Nat Sam likes this.
Far is offline   Reply With Quote
Old   May 23, 2016, 04:18
I'm sorry I did not see that you have posted an answer so I posted my thread again !
That's exactly what I want to do but I could'nt select the corretc vertices...
I was advized to create two surfaces on the either side of the blade and then project the surfaces of my cuboid to them... What do you think ?
My blocking would then look like a cake slice.. DO you see what I mean ?
Thankyou for helping me. Best rgds
Old   May 24, 2016, 06:12
Charles K.
McCharles is on a distinguished road
Best rgds
I'm struggling to understand your blocking, is the cylinder holding one single blade or will there be a few of them around it?
You have to decide if you want a translational or rotational periodicity. If you go to the Tab ''Mesh > Global Mesh Setup > Set Up Periodicity'' You can define the periodicity in function of vector directions (either rotational around an axis with an angle or translational in x,y or z direction). Later on and if needed, you can define a specific Surface/Part of your Geometry as Periodic in the boundary Conditions (Tab Output Mesh > Boundary Conditions) by selection.
If you chose a rotational periodicity, it would be logical to design your blocking as a cake slice around an axis (or in your case, the cylinder).
Hope this will help you!
Nat Sam likes this.
McCharles is offline   Reply With Quote
Old   May 24, 2016, 10:37
You are absolutely right. I wanted to have a cake slice-like blocking. I didn't know I had to create a surface and project my blocking's edges onto it. I did that now and I think I'm in the right direction. Thanks you two for helping me out !
Thread Tools
Trackbacks are On
New Surfaces don't show up in contour plotting menu ExG FLUENT 3 October 20, 2014 14:57
There is no menu bar on paraview simon95 ParaView 2 October 19, 2013 08:59
Plant Menu Scott Phoenics 2 October 6, 2006 04:51
Help for Particles list menu ? Amara CFX 0 November 14, 2003 04:58
Patching with Text Menu Commands Greg Perkins FLUENT 2 February 13, 2001 04:16
