May 29, 2016, 15:54 |
Coordinates Profile Turbogrid
Marta
Hello everybody!
I have a problem with Ansys Turbogrid. I print the hub.curve and the shroud.curve properly, but i cannot understand which coordinate system i have to use to print the right profile.curve (cartesian, cylindrical...). I have a simple extruded compressor blade, and printing the simple cartesian coordinates of the profile I get the trailing edge non attached to the hub and the shroud. Does someone know something about that? |
June 8, 2016, 16:26 |
Marta
I usually use Matlab to work on the airfoil profiles, and I was wondering how could I can elaborate the points and print them to txt files, so that Turbogrid can understand them.
For example, the Nasa Rotor 37's points, available in the Ansys's examples, are wrapped on non-plane surfaces, I think they are like cylinders. |
September 28, 2017, 02:07 |
Umer Sohail
Rep Power: 9 |
Dear friend
I have just start working on rotor 37. I need its blade, hub and shroud curve files. Kindly share its files or geometry. i will be obliged. Thanks |
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
help : import impeller blade coordinates into turbogrid | darKKnight | Main CFD Forum | 1 | February 26, 2016 04:41 |
NACA profile coordinates | melwyn rego | Main CFD Forum | 4 | November 21, 2012 06:44 |
NACA profile coordinates | ken87 | FloEFD, FloWorks & FloTHERM | 1 | March 9, 2011 18:38 |
Unit Vector profile, cylindrical coordinates | Felix | CFX | 3 | February 6, 2009 07:34 |
