June 7, 2016, 06:54 |
preserve faces in volume
Manu Chakkingal
Rep Power: 10 |
Hello
I have a horizontal cylinder inside a cube. It is at the centre of the cube and the end faces of cylnder touches the vertical faces of the cube. I want to do a flow simulation over the cylinder (with heat transfer). So I f I do boolean it is actually removing circular faces of area equal to cylinder top/bottom from the sides of cube. . SO if u look from one end you can see through the cube with cylindrical hole. But I need the end faces of cylinder to be closed. How do I approach it in workbench .
Regards Manu |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 14:49 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
