June 8, 2016, 09:08 |
Pb with the import geometry
Francesco
Rep Power: 9 |
new_NACA-2412.txtHi every body,
i'm working on the NACA 2412 airfoil and after getting my coordinates with Javafoil, i export them into a .txt document. However, when i try to import to Ansys, the error of reading coordinates file appears. So i pissed me off it attach the following document to show you the template that i use to. If every could help me it would be great. Thks to every one |
June 9, 2016, 20:17 |
June 10, 2016, 04:07 |
Francesco
Rep Power: 9 |
Thks a lot. Now it works very well. However, i succeed it in importing the points and then in the 3D curve function I define it from point selection.
have a good day |
[DesignModeler] Unable to Import Geometry | Alan212 | ANSYS Meshing & Geometry | 3 | March 17, 2015 11:26 |
[TurboGrid] import geometry | summerverycool | ANSYS Meshing & Geometry | 5 | July 8, 2013 07:39 |
how to import geometry file to turbogrid | summerverycool | ANSYS Meshing & Geometry | 0 | July 2, 2013 04:44 |
[DesignModeler] Import external geometry problem | Houman | ANSYS Meshing & Geometry | 0 | May 16, 2012 04:24 |
vitual _ real | deneb | FLUENT | 3 | January 22, 2007 04:31 |
