July 4, 2016, 23:48 |
Honeycomb meshing
Hello everybody
I want to mesh a geometry in ICEM. The Geometry is 2 deg and has near 50 repeated honeycomb addition to a stepped labyrinth sealing. Actually I could mesh types of honeycombs one by one (independently). But as I said there is many of honeycombs that I try to find a way for repeat or copy some of blocks that I created hardly for remained parts. Is there anybody to help me? I look forward for your comments. thanks |
July 5, 2016, 04:30 |
Sebastian Engel
Rep Power: 20 |
Hi Saha,
you could make use of the replay function of ICEM. With some work it should be possible to write a script including a loop creating your geometry/blocking. It might be good to do a tutorial in tcl programming language. Have a look here to get an idea: http://www.cfd-online.com/Forums/ans...tml#post603712 With regards, Sebastian |
[ANSYS Meshing] only automatic meshing works, | kazra | ANSYS Meshing & Geometry | 2 | February 23, 2017 11:38 |
[Gmsh] 3D coil mesh: can't create the volume? | RomainBou | OpenFOAM Meshing & Mesh Conversion | 3 | July 18, 2016 05:09 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
Singularity of grid?Volume meshing vs face meshing | Ken | Main CFD Forum | 0 | September 4, 2003 11:09 |
