[ICEM] face is attacted to more than 2 cells
Like Tree1Likes
  • 1 Post By Ronzhao
Old   July 23, 2016, 04:43
Question face is attacted to more than 2 cells
Ron
Ronzhao is on a distinguished road
hello, i am a freshman of the cfd forums. and i have a problem when i output mesh as following statement.
the log: warning: mesh has uncovered faces. ansys fluent need a complete boundary{shells in 3D} or it will give a variety of errors and not read in the mesh.
error:face(near node 135954) is attacted more than 2cells.[and there are hundreds of these errors.]error in computing cell connectivity. child process exited abnormally.
i have searched the published threads, however, i still don't know how to solve the problem. if you know the reason, please tell me, thanks a lot.
Ronzhao is offline   Reply With Quote
Old   July 23, 2016, 10:17
Daniel
Daniel_Khazaei will become famous soon enough
It's probably an association issue with the boundary edges!
if it's a 2D problem then you need to associate every curve to its corresponding edge!
Daniel_Khazaei is offline   Reply With Quote
Old   July 26, 2016, 05:27
Ron
ok. thank you very much, daniel. i have found out that penetrating elements may cause uncouvered face. so, it is better to check mesh to find whether the vertices(of your blocking) is in correct position, because i use the transform mesh!
Far likes this.
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
