[BladeModeler] The inlet and outlet of flow path of an axial turbine
Old   October 2, 2016, 14:40
Default The inlet and outlet of flow path of an axial turbine
Have a nice time!
Ahmed Saeed Mansour is on a distinguished road
Hello, could you tell me why when we define the inlet and outlet sketches to generate the flow path of an axial turbine we draw the inlet and outlet in the axial direction? i think that the outlet is in the direction of the trailing edge...?
Ahmed Saeed Mansour is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump Zev Xavier FLUENT 3 May 9, 2016 07:42
Compressible flow, no data at the outlet mireis FLUENT 6 September 3, 2015 03:10
inlet has higher pressure than outlet in axial flow fan sivakumar Main CFD Forum 37 July 21, 2014 09:34
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
