[ICEM] problem regarding Meshing in ICEM CFD. |
January 15, 2017, 23:44 |
is it possible that i can do meshing of one particular part separately and then import this into my main geometry meshing in ICEM CFD ? Thanks |
January 20, 2017, 12:35 |
Kushal Puri
Rep Power: 12 |
January 20, 2017, 13:26 |
January 20, 2017, 14:19 |
#4 | |
Kushal Puri
Rep Power: 12 |
January 20, 2017, 23:25 |
Okay, how i will import meshing for one part of my geometry in main geometry?
Sent from my C2004 using CFD Online Forum mobile app |
January 21, 2017, 10:08 |
#6 | |
Kushal Puri
Rep Power: 12 |
January 23, 2017, 00:24 |
January 23, 2017, 06:09 |
#8 | |
Kushal Puri
Rep Power: 12 |
if you already have the mesh opening then it will ask for merge, press ok. After that you have to merge the common nodes with tolrance |
January 23, 2017, 06:16 |
#9 |
January 27, 2017, 07:20 |
#10 |
Hi Kushal Puri
I had tried to import meshing and it was quite successful. To define this new imported meshing as solid, I need blocks as well. So when I import blocks for that particular part, it generates new topology. So my meshing has two parts now under these two topology's. So should I convert meshing under these two heads into unstructured mesh separately? Sent from my C2004 using CFD Online Forum mobile app |
[ICEM] Meshing problems using ICEM CFD | TimTUBAF | ANSYS Meshing & Geometry | 6 | January 13, 2017 14:16 |
[ANSYS Meshing] Part missing while meshing in ICEM CFD | Arjun Jayakumar | ANSYS Meshing & Geometry | 0 | October 27, 2014 05:13 |
[ICEM] problem in ICEM CFD | tmeysam92 | ANSYS Meshing & Geometry | 6 | August 11, 2013 13:53 |
[ICEM] problem with meshing in icem cfd | saurabhjoshi2011 | ANSYS Meshing & Geometry | 13 | March 12, 2013 11:27 |
ICEM meshing problem | Forrest | CFX | 4 | May 25, 2005 18:37 |
