Home > Forums > ANSYS Meshing & Geometry
Splitting tube face into two
Old   March 16, 2009, 09:43
Default Splitting tube face into two
Mavis Milton
milton.tafadzwa is on a distinguished road
Dear friends
I have created a tube with height 1420mm and radius 37mm. I have split the tube face into two (lengthwise at centre) so that I have a top face (top wall) and a bottom face (bottom wall). This would allow me to apply two different boundary conditions on the same tube. I exported the mesh but when I read the case only one face (bottom wall) is being shown in Fluent.
Please can you assit me. How do I go about so that all the walls will be visible in Fluent.
Thank you,
Milton
milton.tafadzwa is offline   Reply With Quote
Old   March 16, 2009, 10:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you get a warning while you exported the mesh?
in Fluent how many wall-BC do you have?
-mAx- is offline   Reply With Quote
Old   March 16, 2009, 10:41
Mavis Milton
No I did not receive any warning. I have three wall-BC the top wall, bottom wall and open end on one end of the tube.
Last edited by milton.tafadzwa; March 16, 2009 at 10:45. Reason: left out some information
Old   March 16, 2009, 12:41
-mAx-'s Avatar
Maxime Perelli
ok that means that you set all the extern faces with BC.
If you missed to set any BC, Fluent should create a default "wall" BC.
When you display the grid, you didn't see the top wall? (display faces, enable light and rotate)
Old   March 16, 2009, 20:22
Mavis Milton
The top wall is there on the grid but is missing on the list surfaces, so am unable to set boundary conditions on it. I did create it in Gambit.
Old   March 17, 2009, 01:57
-mAx-'s Avatar
Maxime Perelli
but you said that the top wall is present as BC in Fluent
Anyway, can you provide me your *.dbs file (with rapidshare), I will ltake a look at it
Old   March 17, 2009, 02:37
Mavis Milton
Thanks, I have located where I was making a mistake and the problem is solved.
For interest sake how do I go about to send the .dbs file. This is my first time using this software.
Last edited by milton.tafadzwa; March 17, 2009 at 02:39. Reason: left some information
Old   March 17, 2009, 03:24
-mAx-'s Avatar
Maxime Perelli
you can direct emailed me the dbs file if it is less than 10MB(click on my name and you will have the opportunitiy to mail me)
Or you can upload it on a share server like rapidshare (www.rapidshare)
, and you just have to give the link you receive once it is uploaded
Thread Tools
Trackbacks are On
Tube in Tube heat exchanger( But I got error) Young CFX 2 September 26, 2008 01:35
Tube in a tube how to model tufty OpenFOAM Mesh Utilities 2 June 5, 2007 10:57
U Tube Face linking. Pradeep FLUENT 1 March 20, 2007 06:12
Gambit mesh of tangential tube/tube Christian FLUENT 5 March 27, 2003 04:34
face splitting Althea FLUENT 8 February 2, 2000 18:56
