October 14, 2011, 08:51 |
Urgent help on ICEM CFD
alidogrul
Rep Power: 16 |
I have problem with creating volume which has other volumes inside it. Maybe it is a subtract problem. Can anybody help me?
October 15, 2011, 09:43 |
Simon Pereira
Rep Power: 47 |
This is not usually a problem in ICEM CFD. But you have not even told us which mesh method you are using.
For Tetra and most unstructured methods, you just need to place material points (under create body) in each region. Flood fill will assign the materials without the need for a boolean subtraction or anything like that. For Hexa blocking, you create material points and then split out the regions and assign the blocks to the correct material.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
October 17, 2011, 09:00 |
I thin your problem is not with meshing, i think your problem is with the model, maybe Design modeler if you are using ANSYS.
October 20, 2011, 08:46 |
alidogrul
Rep Power: 16 |
I want to create hexa or hexa-dominant mesh structure.
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Learn ANSYS ICEM CFD | easy_astronaut | ANSYS | 2 | December 15, 2013 15:34 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
Help for ICEM CFD - urgent | Tuks | CFX | 3 | February 8, 2010 03:32 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
