how to create the fluid part in DesignModeler |
March 16, 2009, 13:08 |
Dongzi Wei
Dear all,
I import the geometry created by other CAD tools such as Inventor into DesignModeler, I don't know how to create the fluid part very quickly. I tried the "Fill" tool in DesignModeler. However for simply geometry, it is useful. For complex geometry, I can not use it very well. So does anyone can give some suggestions? Thanks a lot! |
March 20, 2009, 05:42 |
try to create a new volume and substract your imported one with a boolean operation. this way should work.
March 20, 2009, 11:04 |
Dongzi Wei
Thanks for reply.
When creating the new volume, should I pick up the surfaces surrounding the volume one by one? If so, this process is time consuming if the geometry of fluid part is complex. Maybe I am not proficient with DesingModeler, I found that picking up faces one by one is very inconvinient. |
March 23, 2009, 04:51 |
why picking surfaces? just subtract one volume from the other, or does this not work??
March 25, 2009, 09:23 |
Dongzi Wei
Because I need the surfaces to create a new volume for the fluid part. Otherwise, I don't know how to create a fluid volume. Thanks. |
March 25, 2009, 11:54 |
Luis Guillermo V
just go to Tools>Enclosure in Design Modeler. There are many ways of creating enclosure, even your own defined shape.
March 25, 2009, 12:07 |
Dongzi Wei
Thanks.
You are very helpful. |
October 19, 2011, 14:55 |
Nathan
Hi
I have a similar problem , I just thought if you found a solution for it. I have a packing of particles and a fluid surrounding it . I need the design modeler recognize the fluid as a separate zone. Do you have any suggestion? |
October 20, 2011, 01:25 |
You can name the 'Fluid' and 'Particles' for the respective volumes in 'Details' Window. these names will be carried throughout the procedure of the simulation also.
How to create wind turbine blade in DesignModeler | Atit | CFX | 5 | December 26, 2012 06:13 |
How to create airfoil structure in DesignModeler | Richard | CFX | 3 | April 24, 2009 05:29 |
How to create multiple solid-fluid domain? | Harendra | Siemens | 6 | January 28, 2005 13:58 |
How to create the solid and fluid in PROAM? | Ling-Chia | Siemens | 0 | March 3, 2003 02:07 |
Moving part in a fluid | E. BOINOT | FLUENT | 0 | April 24, 2002 09:34 |
