Home > Forums > ANSYS Meshing & Geometry
[ICEM] "segmentation violation" error
Old   March 25, 2009, 14:56
Default "segmentation violation" error
^_^
Jasmine is on a distinguished road
Got this error meassage "segmentation violation" many times. For example, when I tried to generate a find grid in ICEM CFD by chaning the maximum element size from 30 to 24. or even when I check a coarse grid quanlity, the error meassage show up!
I actually just added 2GB memory which is not the same brand as the old 2G meomry. Will that be a problem?
What might be the reason?And how should I deal with it? Thanks in advance.
Jasmine is offline   Reply With Quote
Old   March 25, 2009, 23:49
fauka is on a distinguished road
Hi!!
Most of the cases of "segmentation violation" error are because of memory problems. You can check it with the task manager if there is any such problem. Other than that, I think you need to work on your geometry for holes or any such defects.
fauka is offline   Reply With Quote
Old   March 26, 2009, 17:29
^_^
Thanks!
Well, I changed 2 new memory which is the same brand as my old one, and it works. That kind of error message does not show up so far.
Old   October 29, 2009, 05:49
hashem
hashem_1064 is on a distinguished road
yes, this error is strongly related to the lack of memory.
hashem_1064 is offline   Reply With Quote
Old   October 29, 2009, 08:03
Ryne Whitehill
rwryne is on a distinguished road
I do not think that is the sole case. A coworker and I were getting this message often with ICEM 11. We would basically have to restart the project fresh from the CAD geometry when it would happen. Would use exact same parameters (aka exact same memory usage) and it would work sometimes, others not.
Have not seen this message at all since switching to ICEM 12.
rwryne is offline   Reply With Quote
Old   November 11, 2009, 23:00
Default Clear the memory.
Retired from CFD Online
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Hey Ryne,
It may have been that some processes were still running, or at least still hogging memory. For instance, during the tetra process, elements are swapped around or removed. The matrix keeps the memory slots for these cells for a while and may have an issue clearing the memory in some situations. Other times, a process like Prism.exe may continue to run and be hogging memory even after you think it is done.
The undo buffer may also hog a lot of memory, for instance, if you did a global mesh edit operation operation like converting linear tets to quadratic (or tet to hex), your memory would hold both the old and new tets so that you could "undo" the operation.
Many of these processes, and UNDO its self, were significantly improved at 12.0, which gave us memory improvements, etc. Actually, add mid-side nodes still needs this fix , but at least you can clear the undo buffer easily now.
When you were quitting and restarting 11.0, you were clearing your memory in a rough but effective way.
I am attaching an image of the memory improvements for Octree Tetra at 12.1 (due out later this month).
PSYMN is offline   Reply With Quote
Old   November 12, 2009, 09:12
Ryne Whitehill
Originally Posted by PSYMN View Post
Hey Ryne,
I am excited for 12.1 then!
v12.0 has been great, haven't gotten the segmentation violation error with it. However, I am getting a large memory spike on the "disconnecting orphan cells" step of mesh generation. This often crashes ICEM with no warning (i.e. the process just disappears). I submitted a help ticket to the techsupport who confirmed this spike, and they recommended using batch mode until v12.1 comes out to avoid this. This seems to be working, but I often forget to check the box
Thanks for the reply,
Ryne
Old   December 20, 2013, 18:06
ali
alinik is on a distinguished road
I am getting this error in cfx-solve. Any idea how I can resolve this issue?
I have increased the memory allocation factor upto 10 and still getting the same error. I am running CFX remotely on a linux based supercomputer.
Thanks
alinik is offline   Reply With Quote
Old   January 16, 2015, 06:00
Default how to allocate memory for segemental violation error
vishwanath
vishwanath is on a distinguished road
hi every one,
I am finding error as segemental error. how to resolve it? ...
can you explain the steps to avoid it.
vishwanath is offline   Reply With Quote
Thread Tools
Trackbacks are On
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 18:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user subroutine error CFDUSER CFX 2 December 9, 2006 07:31
