ICEM boundary condition problem
Like Tree1Likes
  • 1 Post By PSYMN
Old   February 10, 2011, 08:46
Default ICEM boundary condition problem
Martin
Martin_D is on a distinguished road
Grettings,
I'm working on an simple 2D simulation of a fluid flow over an airfoil, just to get started with FLUENT and ICEM CFD. I've created a hexa mesh in ICEM following the tutorial of Simon Pereira, which is posted on youtube (thank you Simon ). The only difference is that I don't have a sharp edge airfoil. I've created three parts/ boundary regions: INLET, OUTLET and WALL.
ICEM warns me that I have single edges after checking the unstructured mesh but that isn't a problem in a 2D planer mesh as far as I know. When I convert the mesh to an unstructured mesh the INLET and the WALL become one single boundary region. I have attached a picture for better understanding.
Can anyone help me fix this problem? Thank you.
Regards Martin
Martin_D is offline   Reply With Quote
Old   February 11, 2011, 11:25
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Are the curves under the inlet and wall in separate parts (such as INLET and WALL)? Are the edges associated to those curves? Were you careful to make sure that the edges are not associated to both the INLET and WALL curves? Associating to both would "Group" the curves.
Turn off all the parts except INLET or WALL and turn on all the uns mesh (lines and shells)... What do you see?
hadikhayyamian likes this.
PSYMN is offline   Reply With Quote
Old   February 14, 2011, 10:20
Martin
I've solved the problem. The associations were done incorrectly. I've associated the higher, lower and the left line of the block with the wall and the inlet arc. Changed the associations and got the problem fixed... thanks to you.
Thank you very much for you time and help.
Regards M
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Transient Simulation: Boundary Condition Problem Shafiul CFX 7 January 11, 2011 16:40
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 10:56
How to use a solution as an inlet boundary condition in another problem in fluent geryes FLUENT 0 February 25, 2010 16:32
Problem with ambit Lio FLUENT 4 July 6, 2004 08:23
