[ICEM] Applying surface mesh settings
Old   August 13, 2009, 06:40
Default [ICEM] Applying surface mesh settings
siw
Stuart
siw will become famous soon enough
Probably a simple question but anyway.
I've selected some surfaces in the Surface Mesh Setup and have applied a maximum size. But I now want to have a smaller tetra size on these surfaces instead. But now when I open Surface Mesh Setup I have to reselect all the surfaces again and type in all the values - rather than just modify the single value I need to. It's as if I was starting at the beginning again.
There must be a feature, like in CFX-Mesh, that lists all the surface and edge sizing parameters so you only have to choose that and it recalls all the parameters.
Thanks
siw is offline   Reply With Quote
Old   August 20, 2009, 18:01
Default group into parts or subsets.
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
You can collect all the surfaces of the same size into parts or subsets and then apply settings to those parts or subsets...
PSYMN is offline   Reply With Quote
Old   August 21, 2009, 02:16
siw
Stuart
Thanks PSYMN.
[Netgen] Volume mesh instead of surface mesh phan OpenFOAM Meshing & Mesh Conversion 4 October 18, 2009 17:17
Mesh generation from surface model wei Siemens 2 April 24, 2009 02:33
Mesh @ Free Surface MAB CFX 7 May 29, 2008 04:48
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
Interpolating volume data onto quad surface mesh N.R. CFX 6 June 7, 2007 08:15
