Home > Forums > ANSYS Meshing & Geometry
[GAMBIT] Fixing a poor quality mesh
Old   April 21, 2009, 10:50
Question Fixing a poor quality mesh
Forrest's Avatar
Forrest is on a distinguished road
In a portion of my geometry, I have a volume that is not meshing very well. I am able to generate and "o-grid" (Blue mesh in the pictures) easily with the hex/map volume mesh. I want to use prismatic cells to fill the rest of the domain (the red mesh) using the cooper scheme. I have been somewhat successful getting this to work. Right now, the red mesh has a an equiskew size of 0.91. If I change the edge meshing straight piece of the source face even a little, this number goes up and sometimes I even get inverted cells. What is the best way to reduce my equiskew size for this type of mesh? Thanks in advance.
Forrest is offline   Reply With Quote
Old   April 21, 2009, 13:58
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Why don't you try to fill it wit tet-hexcore?
Gambit will generate the outer layer with tetra and prism and the core with hexa.
If you still want prism, then I would suggest splitting the volume along its axis (y).
The problem here, is that Gambit has to project an half disk onto an half "rectangle".
You can help gambit, if the projection is generated in more than one step
-mAx- is offline   Reply With Quote
Old   July 15, 2010, 18:45
Default in order to have a better quality of your mesh
Domenico
c120613 is on a distinguished road
Hi man, I got a problem like yours, and then I started to think to divide my domain in several blocks. At the end of the day I achieved a good results by generating several blocks and the mesh is structured everywhere. First of all try to create the central part of your mesh at squared base instead of circular.
c120613 is offline   Reply With Quote
Old   December 15, 2010, 12:48
roger
roger_pn is on a distinguished road
What do you mean with inverted cells? I have a problem when doing the Grid in Fluent that says I have inverted elements and non-positive volumes. I'm trying to mesh an airfoil.
roger_pn is offline   Reply With Quote
Old   December 16, 2010, 10:44
-mAx-'s Avatar
Maxime Perelli
Go to examine Mesh and check where are those cells (choose Volume in quality type and set lower and upper limit for displaying only negative cells).
Most of time, you will understand the problem as you see where are bad cells
In memory of my friend Hervé: CFD engineer & freerider
Old   December 18, 2010, 13:44
Sowmya K
skris2009 is on a distinguished road
Forrest, if this is some of a circular-to-rectangular transition duct, then it might be worth while for you to look at a Pointwise/Gridgen tutorial example, where creating a grid for the same geometry has been shown very clearly.
I struggled with very poor quality meshes for a transition duct as well (it is for my masters thesis). Why don't you use a 'Pave' hex unstructured mesh in the interior instead of a tet mesh? I did find it that it helps in reducing the skewness.
skris2009 is offline   Reply With Quote
Thread Tools
Trackbacks are On
virtual geometry richard FLUENT 4 January 7, 2009 06:16
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 13:47
