Home > Forums > ANSYS Meshing & Geometry
gambit 64 bit??
Like Tree7Likes
Old   September 9, 2013, 13:14
ghost82's Avatar
Daniele
ghost82 will become famous soon enough
Originally Posted by Volker P. View Post
There is a 64 bit GAMBIT version for Linux. For large grids > 6 millions it seems to be the right answer. Unfortunately Fluent never managed to support OpenGL with that release whereas the 32 bit version does. It should be just vice versa, since shading with lots of geometry details and lots of cells which makes 64 bit inevitable can take some seconds with the normal graphics system X11 and becomes a burden whereas shading with OpenGl makes really fun.
Volker
Quite old thread, but maybe someone can be redirected to the right place to make gambit works with opengl and linux:
http://www.cfd-online.com/Forums/ans...tml#post450714
Daniele
ghost82 is offline   Reply With Quote
Old   November 19, 2016, 07:56
Default Which linux distros support Gambit 64bit?
  #22
George Pichurov
jorkolino is on a distinguished road
To all guys that installed Gambit 64 bit on LInux. Which Linux distribution do you use? Do I need necessary RedHat or SLES? I have hard time finding working 64 SLES that supports gambit, and Red Hat is commercial.
(As a side note, people asking about the Gambit 64bit linux version, it should be available in the download page of the fluent.com and later ansys.com portal. I believe I downloaded it there)
jorkolino is offline   Reply With Quote
Old   November 19, 2016, 08:52
ghost82's Avatar
Daniele
I installed it on sles 11 sp2. I remember I was able to install it on ubuntu/kubuntu (I don't remember version) after some tweakings.
Google is your friend and the same for the search button!
Old   November 21, 2016, 02:07
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I was able to install it on caelinux (ubuntu distribution)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Thread Tools
Trackbacks are On
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
help or suggestion required -64 bit linux + gambit Ramesh.K FLUENT 2 October 20, 2008 14:14
Gambit 64 bit Omar FLUENT 3 July 11, 2008 06:03
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 09:33
Athlon 64 Gambit Compatibility? Derick FLUENT 3 January 17, 2006 18:28
