May 13, 2009, 15:01 |
Creating far field
muhammad usman
hello i wana to know how to creat a far field in ansys . i have imported a cad geometry in ansys desigm modeler and i wan to creat the far field
urgent please |
May 14, 2009, 15:29 |
tools => enclosure
Simon Pereira
Rep Power: 47 |
The best way is to go to “tools => Enclosure” set the cushion and Generate…
Or to do it more manually, go to Create => Primatives, or somehow create a volume around your object. When you create the new solid, be sure to set operation to “Add Frozen” or it will fuse the two solids together. Now that you have a Frozen far field around your model, you can use Create => Boolean to subtract the solid from the farfield… |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
Phase locked average in run time | panara | OpenFOAM | 2 | February 20, 2008 15:37 |
Problems with Meshing: Collapsed Cells | Emmanuel Resch | Siemens | 1 | July 30, 2007 04:02 |
Creating a mesh of the flow field in GAMBIT | Vidya Raja | FLUENT | 0 | October 3, 2005 10:53 |
