[GAMBIT] how to generate orthogonal mesh using GAMBIT? |
May 13, 2009, 15:24 |
Ivan
I am trying to generate a mesh around an airfoil using GAMBIT. The mesh needs to be structured and orthogonal in the boundary layer. Structured mesh is not a problem, but I just cannot make it orthogonal in the boundary layer. After a lot of attempts and search online, I am almost convinced that Gambit cannot generate orthogonal mesh.
Any suggestion will be appreciated! |
October 19, 2009, 11:45 |
Stuart
Rep Power: 25 |
I, too, would also like to know the answer to this old(ish) question.
Can anyone help? |
October 20, 2009, 02:51 |
Maxime Perelli
Rep Power: 41 |
Gambit can build whatever you want.
You just need to build a topology around your airfoil, which enable a full orthogonal mesh. For the BL, you aren't forced to use the BL-toll, but you can create a subvolume surrounding your airfoil (that will be your BL). From that, you can continue building the topology by creating subvolumes orthogonal to this prior subvolume
In memory of my friend Hervé: CFD engineer & freerider |
October 20, 2009, 11:21 |
Stuart
Rep Power: 25 |
So there's no option to ensure that quad boundary layer elements are forced to be perpendicular to the edge/surface they are on - or even a text command that can be put in a journal file?
For my model (which is not an aerofoil) making extra geometry instead of using the in-built boundary layer mesh features is a real pain. |
October 21, 2009, 02:21 |
Maxime Perelli
Rep Power: 41 |
I didn't pay attention on what you wanted, I thought you were expecting an orthogonal mesh around the BL.
Can you post a picture of your issue
October 21, 2009, 03:54 |
Stuart
Rep Power: 25 |
I've attached two areas were my boundary layer is not perpendicular to the surface.
I can understand that the line on the corner tip cannot be perpendicular to anything, but I would expect Gambit to allow all the other line to be made perpendicular if the User want them to be. |
October 21, 2009, 04:07 |
Maxime Perelli
Rep Power: 41 |
I suppose it is because of the meshed edge grading.
Is your curved surface isolated or it is merged with another one? If it is merged, try to split it (to isolate only the curved surface). Then try to apply the BL only on the curved surface. If you the issue isn't solved, as I said you can try to create a surface surrounding your body. With splits, etc... you can enforce having a full orthogonal mesh. The last version of Gambit has a offset tool in the surface panel. So you can offset your body's surface, and juste split your volume with it. Hope it helps
October 21, 2009, 04:36 |
Stuart
Rep Power: 25 |
Yes, all the boundary layers are linked together so, as you say, the grading is causing this, but I had expected that feature could be switched OFF.
I did change the default parameter MESH.BLAYERTGRID.ORTHOGONAL_LAYERS to 15 (this is my quanity of layers) but that made no difference. So I'm guessing that this option is not being used. How deterimental are these tilted elements compared to perfect quad elements on a solution? Since i will not be able to get perfect quad elements I can't compare solution results. |
October 21, 2009, 04:41 |
Maxime Perelli
Rep Power: 41 |
no idea about the parameters, and I wouldn't play with them.
Try to isolate the curved surface and apply the BL on this surface.
gambit orthogonal mesh |
Maximum no. of mesh fixed at 100k in Gambit? | Peter | FLUENT | 5 | July 16, 2008 21:44 |
Use Gambit to generate 3D mesh ! ! ! | yuanye | FLUENT | 0 | June 3, 2008 23:03 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
Mesh Resolution in Gambit | Vidya Raja | FLUENT | 2 | January 19, 2006 00:35 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 04:10 |
