Creating far field
Old   May 13, 2009, 14:01
Default Creating far field
muhammad usman
musman is on a distinguished road
hello i wana to know how to creat a far field in ansys . i have imported a cad geometry in ansys desigm modeler and i wan to creat the far field
urgent please
musman is offline   Reply With Quote
Old   May 14, 2009, 14:29
Default tools => enclosure
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
The best way is to go to “tools => Enclosure” set the cushion and Generate…
Or to do it more manually, go to Create => Primatives, or somehow create a volume around your object. When you create the new solid, be sure to set operation to “Add Frozen” or it will fuse the two solids together. Now that you have a Frozen far field around your model, you can use Create => Boolean to subtract the solid from the farfield…
PSYMN is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 14:37
Problems with Meshing: Collapsed Cells Emmanuel Resch Siemens 1 July 30, 2007 03:02
Creating a mesh of the flow field in GAMBIT Vidya Raja FLUENT 0 October 3, 2005 09:53
