Home > Forums > ANSYS Meshing & Geometry
Curved triangle elements
Old   May 14, 2009, 12:28
Default Curved triangle elements
realanony87 is on a distinguished road
I am trying to mesh a 3-D wing using the Robust Octree approach.
The problem I have is the elements near the leading edge of the wing are straight and therefore do not capture the geometry of the wing like when I create a mesh with ICEM hexa. Is there a way to make the tetras curved as to fit on the geometry exactly =?
thanks
realanony87 is offline   Reply With Quote
Old   May 15, 2009, 09:45
Default MidSideNodes?
PSYMN's Avatar
Simon Pereira
PSYMN has a spectacular aura aboutPSYMN has a spectacular aura about
Curved elements are “quadratic”. You can convert linear to quadratic using “Edit Mesh => Convert Mesh Type => Create Mid Side Nodes”
However, be sure that your solver accepts “curved” elements.
Instead, you may want to simply put smaller mesh in these areas. This can be done with a surface mesh parameter, or with curvature based refinement.
Others prefer to map the mesh along the wings with one of the other ICEM CFD meshing algorithms such as Hexa or MultiZone…
PSYMN is offline   Reply With Quote
Thread Tools
Trackbacks are On
elements, nodes and faces Andy CFX 10 July 7, 2013 22:40
IdeasUnvToFoam Bug amp Fix benru OpenFOAM Bugs 42 November 13, 2009 08:59
High Aspect Ratio elements Flavio CFX 2 November 24, 2006 13:01
Penetrating elements in extruded mesh Michael P CFX 2 May 20, 2005 08:06
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
